bmw help - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Car Specific Forums > BMW
Old 01-11-2009, 06:12 PM   #1
LittleRed
Shift_Mazda
LittleRed's Avatar
LittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really niceLittleRed is just really nice
Send a message via AIM to LittleRed
bmw help
i make a intake and put all the sensors and hoses back in the tube i made but it seems to run a little diff so i took one sensor out of the tube and it seemed to be better. the sensor i took out has coolant that runs through it. any ideas what i shoud do with it? just leave it out and zip tie it off to the side?
Old turbo rx-7
miata in progress
dodge aries dd
06 mazdaspeed 6
xbl game tag:littlered1988
LittleRed is offline   Reply With Quote
Old 01-11-2009, 06:22 PM   #2
can you take a pic of this sensor?? I work on a lot of these and i'm not sure what yo are referring to
Old 01-11-2009, 07:22 PM   #3
Zerolift01
Zerolift01 has a spectacular aura aboutZerolift01 has a spectacular aura aboutZerolift01 has a spectacular aura aboutZerolift01 has a spectacular aura aboutZerolift01 has a spectacular aura aboutZerolift01 has a spectacular aura about
This part has two small coolant lines attached to it.? Is this the part in the picture #11 ?
ZEROLIFT AUTOLAB - 513.874.2508 - www.zerolift.com - Robert@zerolift.com -
http://www.facebook.com/Zerolift
Zerolift01 is offline   Reply With Quote
Old 01-11-2009, 07:42 PM   #4
CASANOVA
Just the Tip...
CASANOVA's Avatar
CASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to allCASANOVA is a name known to all
Yeah that's it, we figured out that it's the air box thermostat
1990 Mazda Miata
CASANOVA is offline   Reply With Quote
Old 01-11-2009, 07:46 PM   #5
I'd zip-tie it some where close to the front bumper where it can get the correct air temperature...
ummmm... the front bumper is not going to be the correct air temp for the intake air temp reading...... did this have a hot air valve on the air box orig??
Old 01-11-2009, 07:57 PM   #6
CASANOVA
Just the Tip...
CASANOVA's Avatar
Yeah, you're right.
Old 01-11-2009, 10:47 PM   #7
altima3.5se
shift_DEAD
altima3.5se's Avatar
altima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nicealtima3.5se is just really nice
Send a message via AIM to altima3.5se
i did a little research and all it is a valve that lets coolant run through the throttle body. so he could just cap the lines off if he wanted i dont think is attached to the ECU in anyway. its just to keep the air temps coming into the engine consistant. when its cold it lets the coolant flow through to warm it up and shuts when it gets warm. i know that the aftermarket intake manifold caps the coolant hoses to my throttle body
altima3.5se is offline   Reply With Quote
Old 01-11-2009, 10:59 PM   #8
LittleRed
Shift_Mazda
LittleRed's Avatar
thanks for the help guys. i moved it down by the filter and it seems to be fine now. i may cap them if i find out everything works that way lol
