And yes horribly fucked axles will do the same thing. Usually you can grab a hold of the outer joint region and manhandle it enough to feel the play if they are fucked up enough to cause a bad vibe. I repaired a Kia sephia that had thoroughly fucked axles and a bad vibe.
And broken belts in your tire will do the same thing.
