4g63 Timing problems - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Engine Tech
Old 06-09-2004, 04:49 PM   #1
ObsesseDSM
living it up
ObsesseDSM is infamous around these partsObsesseDSM is infamous around these parts
Send a message via AIM to ObsesseDSM
Put a junk head on and timed it perfectly no problems. Get the head rebuilt and i can hardly get the fucking belt on let alone the tensioner.
I am aligning my cam gear marks and then working the way down to the bottom marks. I am not even leaving the extra tooth on the tensioner pully side so when it gets tension it doesn't put everything off a tooth. When i do get the belt on which is a rare case it is tight as hell. I can't even push the damn pully up enough to get the tensioner in there secure...and yes the tensioner is compressed. wtf am i doing wrong? I'm about to try lining the bottom up and trying to get it over the cam gears next.
ObsesseDSM is offline   Reply With Quote
Old 06-09-2004, 07:37 PM   #2
Red Sleeper
All time 4x4
Red Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the roughRed Sleeper is a jewel in the rough
Send a message via AIM to Red Sleeper
haha... there is an idler pullier that the tensioner pushs on. It is adjustable. I had the same problem at 1 time. Just loosen the pully. turn it a bit and it will loosen or tighten up. Sinmple im me for more details. if needed.
Red Sleeper is offline   Reply With Quote
Old 06-10-2004, 12:25 AM   #3
LaserRS
CinciDSM
LaserRS is on a distinguished road
Send a message via AIM to LaserRS
Yeah what he said. Its the pulley with the bolt thats offset (i.e. not in the center) Loosen that and you'll be fine.
LaserRS is offline   Reply With Quote
Old 06-10-2004, 01:13 AM   #4
9secondtalon
Scot
9secondtalon's Avatar
9secondtalon is on a distinguished road9secondtalon is on a distinguished road
"You have learned well Pond Skipper and Grasshopper"
Scot referring to red sleeper and laserrs. :grinbounc
9secondtalon is offline   Reply With Quote
Old 06-10-2004, 05:24 AM   #5
red90AWD
Rotten Egg
red90AWD is on a distinguished roadred90AWD is on a distinguished road
Send a message via AIM to red90AWD
scot your goofy matt
red90AWD is offline   Reply With Quote
Old 06-10-2004, 07:02 AM   #6
Red Sleeper
All time 4x4
haha thanks. Even tho it doesnt make sense. Well the pond skipper and grasshopper thing anyway
Old 06-10-2004, 05:20 PM   #7
red90AWD
Rotten Egg
did u do the timing yet?? did everything work out ok?? matt
Old 06-11-2004, 04:35 PM   #8
ObsesseDSM
living it up
well i went from the exhaust sprocket clockwise and got the belt on alright. I didn't adjust the tensioner pulley or ilder pulley although i did remove the tensioner pulley when installing water pump.. Since i did get the belt on and timed correctly does it matter if the bolt holding the pulley is offset as long as the bolt is torqed to spec?
comp is 160 accross...
scott i need another mbc...
