My slow STI - Page 5 - Cincy Street Scene
Old 02-19-2013, 10:11 AM   #81
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
Carbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of lightCarbon01GT is a glorious beacon of light
Originally Posted by SloRice View Post
It was typical CSS joke but if you're serious....I really do have $5k cash moniez to give!
I was being facetious
Carbon01GT is offline   Reply With Quote
Old 02-19-2013, 01:27 PM   #82
$5100 cash moniez?
Old 02-19-2013, 02:33 PM   #83
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
We're not too far apart
Old 02-19-2013, 02:34 PM   #84
Ok 5150. Final offer.
Old 02-19-2013, 03:31 PM   #85
Ls1Rule
Ls1Rule will become famous soon enoughLs1Rule will become famous soon enoughLs1Rule will become famous soon enough
$1 Bob
98 Formula-224 cam, headers
Ls1Rule is offline   Reply With Quote
Old 02-20-2013, 03:59 PM   #86
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
2012 engine does not like 2004 car.
Swapping 2004 intake cams in Thursday night.
If this doesn't work, it's LSx swap time.
Old 02-20-2013, 04:08 PM   #87
Whats different between the two engines?
Old 02-20-2013, 04:09 PM   #88
Joey
D-Bag Mode On!
Joey's Avatar
Joey has a spectacular aura aboutJoey has a spectacular aura aboutJoey has a spectacular aura aboutJoey has a spectacular aura aboutJoey has a spectacular aura aboutJoey has a spectacular aura about
8 years?
Joey is offline   Reply With Quote
Old 02-20-2013, 04:21 PM   #89
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
2004-2007 have avcs (variable valve timing) on the intake side only. 2008+ have it on both intake and exhaust.
I'm currently running '12 intake cams and '04 exhaust cams with '04 cam gears on everything. I had to do this, as the 2004 ecu doesn't support exhaust avcs. We are swapping '04 intake cams in as the centerlines may be different as well as trigger points on the cams for avcs.
There's also air pumps on the 08+ engines for emissions that just blow fresh air through the heads, but those are deleted with block off plates.
Old 02-20-2013, 05:41 PM   #90
Did you swap the crank pulley?
one is not like the other, '03 vs '06 Forester, ECU was not getting proper signal and throwing codes
It wasn't the ECU or the timing belt. It was actually the crank gear. Car was throwing a crank position sensor code after re-assembly and generally running like shit. It'd fire up, but backfire a lot and miss. It was running lean and wasn't able to be revved much past idle.
Old 02-20-2013, 05:52 PM   #91
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
No codes are thrown. If it were a crank gear issue, the ecu would notice. The crank sensor was also replaced.
Old 02-20-2013, 06:22 PM   #92
Just relaying what a friend on a private forum found out.
PS: He's also swapping a LSI into his Jeep :)
Old 02-20-2013, 06:59 PM   #93
You might want to double check that, actually the ecu isn't going to know anything is wrong as it references EVERYTHING else off the crank signal.
If the triggers are different its going to try and fire things and look for cam reference at the wrong time.
Pretty easy thing to swap compared to cams....
Old 02-20-2013, 09:38 PM   #94
Found the solution to your problem:
Remove the EJ25 engine and throw it in the dumpster. Take the LS6 sitting next to the vehicle, and put that in instead. It'll take more work, but you've already got a headache.
Old 02-20-2013, 09:52 PM   #95
Does it have gas in it?
Lol just sayin
Old 02-20-2013, 09:55 PM   #96
why not change ecus?
I am the 53%
Old 02-20-2013, 10:03 PM   #97
Carbon01GT
a.k.a. Badmeat
Carbon01GT's Avatar
It would need an ecu and complete harness swap. More of a headache.
I'll just swap the crank gear while I've got everything off anyway.
Old 02-21-2013, 04:09 AM   #98
ECU pin outs are different.
Old 02-21-2013, 08:59 AM   #99
Ackbar00
Admiral of the Smack Talk!
Ackbar00's Avatar
Ackbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the roughAckbar00 is a jewel in the rough
A guy in Dayton tried this once. Didnt fair to well for him
1993 Mustang GT
"The Truth is, Your the Weak, and I am the Tyranny of Evil Men!"
Originally Posted by BlackWagon
It only means that you'll be the last one standing when everyone else shakes their head in shame and walks away.
Originally Posted by BES_Stroked_Nova View Post
camaro's junk. buy a mustang.
Click here, to see the funniest thing on the internet.
Ackbar00 is offline   Reply With Quote
Old 02-21-2013, 09:47 AM   #100
I would rather swap pinouts than tear down a motor... particularly if it makes a performance difference...
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
