T25 boosting issue, VERY weird, help me out here. - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Engine Tech
Old 03-08-2011, 02:07 AM   #1
KEMP
#1 loved by CSS
KEMP's Avatar
KEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these partsKEMP is infamous around these parts
Ok, so first off there is ZERO boost leaks, the system held 30psi with not problem by boost leak testing it thru the intake of the turbo. It spools(you can easily hear it) but it makes zero boost to the intake manifold. note that wastegate has been checked, it seals, and the actuator is fine.
I hooked up my autometer gauge to the compressor housing, and left my EBC hooked up to read boost from the I/M, so i could see boost from the turbo and from the I/M. I un hooked the wastegate vac line to run free boost to see if it would boost at all. It made 12 psi at the turbo and 0-3psi at the intake manifold only under load in 3rd/4th gear. as you know on free boost the turbo should spool to the sky, and make atleast 20psi, but no, it only made 12. is seems the turbo is not making enough CFM to get the boost to the I/M. there is ZERO smoke, and minimal side to side and minimal in and out play... EVERYTHING else has been checked and still getting no results, the wastegate flap is not broke, there is no exhaust leaks or cracks anywhere, i even wired the flap shut and drove it, and still nothin, even with a boost controller hooked up, no change.
im thinking the turbo is shot and not creating enough cfm due to clearance in the compressor blade not being have to actually fully compress. im fairly sure its the turbo, im not sure what else it could be.
If anyone could shed some light on this that would be very helpful, im sure someone has had a similar problem... please no flaming, im just asking for a little help here, thanks you in advance.
p.s. im pulling the turbo tonight, to take it apart and check the exhaust blades and everything else. Also the motor compression tested great and the leak down was 5-7% across all 4 cylinders.
also someone said something about ignition timing could cause this, but im not to sure on that, either way the turbo should be making more than 12psi at the compressor with the wastegate on free boost.
Thanks.
1990 240sx - CA18DET, full 180sx conversion, stock motor, drift car.
2002 325ci- Stock, 5spd, fully loaded, m-tech
SHIFT_Lag
SlowCarCrew
KEMP is offline   Reply With Quote
Old 03-08-2011, 09:28 AM   #2
Larimer
CSSmakesyoudumb
Larimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the roughLarimer is a jewel in the rough
Send a message via AIM to Larimer
I'm betting you're missing some blades. Does the shaft spin freely?
http://i1012.photobucket.com/albums/af241/Larimer13/ai-yay-miata.jpg
Larimer is offline   Reply With Quote
Old 03-08-2011, 09:38 AM   #3
ForceFed
Fu(k (ivility
ForceFed's Avatar
ForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the roughForceFed is a jewel in the rough
Send a message via AIM to ForceFed
How do you make boost at the turbo and not in the piping or intake manifold? It's all connected, so how is this possible?
ForceFed is offline   Reply With Quote
Old 03-08-2011, 09:49 AM   #4
HATEMENOW
Im just playin.
HATEMENOW's Avatar
HATEMENOW is a jewel in the roughHATEMENOW is a jewel in the roughHATEMENOW is a jewel in the roughHATEMENOW is a jewel in the roughHATEMENOW is a jewel in the roughHATEMENOW is a jewel in the roughHATEMENOW is a jewel in the rough
Send a message via AIM to HATEMENOW Send a message via Yahoo to HATEMENOW
open d/v? or hooked up backwards?
HATEMENOW is offline   Reply With Quote
Old 03-08-2011, 11:01 AM   #5
Meeners
Angry African
Meeners's Avatar
Meeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to allMeeners is a name known to all
Send a message via AIM to Meeners
I had this same problem on my bluebird Travis... I thought it was the turbos too so I bought a new gtir t28 and it didn't help... I sold them and both people I sold them to had success with the gtir turbos. See if someone has an extra t25 laying around and try that... Then I thought it was my actuators, so I bought many new ones, still not it. Mine held pressure as well... Zero leaks... Swapped out my BOV's, Blocked it off completely, NOTHING... Over a YEAR of bull shit. Do a compression and leakdown test. Only thing I think I didn't check was my IACV/AAC
I thought I damaged my valve seals by pressure testing so much. It didn't make sense AT ALL... I still never figured it out, car ran fine... just wouldn't build and was erratic.
98 Subaru Forester S Turbo | 90 Mazda Miata Turbo | 08 KTM 250sx SuperMoto | 04 Aprilia Tuono 1000R
Shift_Yo Paradigm Ma Fahka.
Meeners is offline   Reply With Quote
Old 03-08-2011, 12:24 PM   #6
dsmgod24
dsmgod24 is on a distinguished road
Obviously you have a problem from the comp. side to the IM as far as a leak... better boost leak test it again with a smoke machine to see if you can see where its leaking. If that is all good most likely the turbo is damaged due to serveral different reasons... Lack of oil, old turbo, worn out seal, etc.
570awhp pump gas (old worn out engine)
New engine making great power.
dsmgod24 is offline   Reply With Quote
Old 03-08-2011, 12:51 PM   #7
Meeners
Angry African
Meeners's Avatar
It's not obvious... even though the pressure test will hold it wont build boost. This is why it's confusing. After 20 or so pressure tests on a compressor and with a homemade pressure tester, no drop. That is exactly what was going on with mine.
Old 03-08-2011, 04:19 PM   #8
S14Daver
CSS adict
S14Daver's Avatar
S14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of lightS14Daver is a glorious beacon of light
Send a message via AIM to S14Daver
I can vouch for Ameen checking everything on his car A LOT, it never made sense. Strangest thing ever, hope you figure it out.
'12 Civic
'76 280z
S14Daver is offline   Reply With Quote
Old 03-08-2011, 04:35 PM   #9
Fractur3
Fractur3's Avatar
Fractur3 has a spectacular aura aboutFractur3 has a spectacular aura aboutFractur3 has a spectacular aura aboutFractur3 has a spectacular aura aboutFractur3 has a spectacular aura about
Obviously its not the turbo, if its making 13psi at the turbo, theres a blockage somewhere between the compressor and the intake manifold. Maybe someone shoved a towel into the intercoooler and its limiting airflow? Check for simple shit like that, pull the whole IC off and make sure nothing is clogging it.
Fractur3 is offline   Reply With Quote
Old 03-08-2011, 05:41 PM   #10
shiftdrift
Banned
shiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these parts
if you can, run just tubing from the turbo to the intake with the intercooler off, that will tell if there is a restriction there or not.
shiftdrift is offline   Reply With Quote
Old 03-08-2011, 06:03 PM   #11
This. Did you buy a intercooler off ebay that was designed for a fighter jet or something?
Old 03-09-2011, 03:08 AM   #12
KEMP
#1 loved by CSS
KEMP's Avatar
well after checking/adjusting timing(it was reallly laggy and i hadnt thrown a timing light on it, so i finally got the response back, it still spooled the same but) it made 5psi last night to the intake, it spools but i finally think i figured it out... i finally got some puffs of blue smoke from the turbo...so i pull the intake off... it has in and out play, not much but enough to hear a "click" when moving it in and out... and play side to side/up and down..so as a reference i felt my t70 that is known blown..side to side around the same as the t25 but had ZERO in and out.
thanks for the help guys, im pretty sure this is the problem, and just finally started getting the puff of blue smoke to top it off and turn on a light bulb above my head, that it was compressing but not making enough cfm to carry it to the intake.
i also compression tested it again and leak down again to make sure it was indeed turbo smoke... same numbers as last time all good.
p.s. i did hot-pipe the turbo/throttle body and it made more boost but not much, either way, running free boost that turbo should spool atleast 20 psi, and it never reached about 12 at the compressor
feel free to add anymore ideas, if this doesnt work, im gonna burn the damn thing to the ground hahah, at that point ill check the IACV like ameen stated, but i cant imagine what it could be if this doesnt fix it, but im pretty convinced its the turbo
Old 03-09-2011, 09:51 AM   #13
That's pretty much inevitable...
Old 03-09-2011, 10:23 AM   #14
KEMP
#1 loved by CSS
KEMP's Avatar
bring the gas, i got the match haha
but im leaving now to pick up my new turbo
Old 03-09-2011, 10:28 AM   #15
Larimer
CSSmakesyoudumb
I was hoping you were going to find blades clogging your intercooler. haha.
Old 03-09-2011, 12:00 PM   #16
dsmgod24
Even if there were blades in the intercooler from the comp. side it would still flow air as long as it didn't put a hole into it.
Old 03-09-2011, 12:00 PM   #17
dsmgod24
Go get a 14b or something a little bigger.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
