Gas in the oil - Page 2 - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Engine Tech
Old 04-11-2011, 11:05 AM   #21
stang99gtv8
Bang Bang
stang99gtv8's Avatar
stang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nicestang99gtv8 is just really nice
Originally Posted by schrags View Post
Do you take a lot of short drives, like only a few miles?
No, actually most of the drives are 10 miles or more. It also sometimes feels like it's hesitating slightly when taking off in 5th gear on the highway, but I don't feel that when i drop down to 4th gear (out of 6, 6 being an overdrive gear).
Veritas et Aequitas
NRA Certified Instructor
Basic Pistol (CCW) - Personal Protection Inside The Home
R.I.P. Hot Rod - Ahmed - Colt45
stang99gtv8 is offline   Reply With Quote
Old 05-13-2011, 04:39 PM   #22
boostedcoupe
TD04-13T FTL
boostedcoupe's Avatar
boostedcoupe is on a distinguished roadboostedcoupe is on a distinguished road
Originally Posted by WhiteT View Post
I'd say a badly designed pcv system could cause it. The pcv system is supposed to suck up and combust all the fuel and water vapors in the crank case. Also an overly rich condition can cause it too.
If you pull the pcv valve with the car running , do you have a vacuum at the valve?
It's both of the above, most likely. The new Hyundai turbo engines put an inordinate amount of oil and oil vapor thru the pcv, and since they run really rich stock, it thins it out. In every catch can I've seen on a GC (mine's not installed yet), there's always at least 20 mL of oil that reeks of gasoline every 3k miles. Some even find a little coolant/water vapor. Check inside of your pre-turbo inlet piping and it's probably covered in a thin layer of oil. Install a catch can on the throttle body side (if not in vacuum line on passenger side before the intake too) and get a tune. That should solve the problem.
boostedcoupe is offline   Reply With Quote
Old 05-13-2011, 05:18 PM   #23
Mike
Fat Ricer Admin
Mike's Avatar
Mike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud of
Send a message via AIM to Mike
Sounds like a "get whatcha pay for" kinda situation.
You bought a second rate car companies attempt at a turbo sedan. Paint me shocked tha pile is having issues
Mike is offline   Reply With Quote
Old 05-13-2011, 05:26 PM   #24
xander
2,000 posts club
xander's Avatar
xander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to allxander is a name known to all
Send a message via AIM to xander
I know a guy who bought one of these and within a week returned it to the dealer. I forget what problems he had with it though.
xander is offline   Reply With Quote
Old 05-13-2011, 05:30 PM   #25
boostedcoupe
TD04-13T FTL
I wouldn't say they're bad/cheap cars. It could use a little refinement, but a $50 fix to have a decently performing turbo car for less than $25k is worth it to me
Old 05-13-2011, 06:02 PM   #26
Widebody
2,000 posts club
Widebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of lightWidebody is a glorious beacon of light
Send a message via AIM to Widebody
I would take this one back and get a new one to try the catchcan on. You could only have 10k miles on the car and have 50k in wear on the engine from this. You have the chance to return it so do it.
Widebody is offline   Reply With Quote
Old 05-13-2011, 06:14 PM   #27
srt21
I FASTR
srt21's Avatar
srt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nice
Send a message via AIM to srt21
Decently performing? You must have one lol
srt21 is offline   Reply With Quote
Old 05-13-2011, 06:38 PM   #28
boostedcoupe
TD04-13T FTL
Yup lol. There are guys who put less than 3k into a base 2.0T and are putting down over 350whp (doing the work themselves, obviously)
Old 05-13-2011, 07:08 PM   #29
srt21
I FASTR
srt21's Avatar
Is that a lot?
Old 05-13-2011, 07:17 PM   #30
boostedcoupe
TD04-13T FTL
needz moar. Should just drop in a 2JZ and put a bunch of decals on it.
Old 05-13-2011, 07:25 PM   #31
that comment that kid made is never gonna die
Old 05-26-2011, 05:45 PM   #32
boostedcoupe
TD04-13T FTL
I was reading this article on Gencoupe.com and found that the issue might be partially due to improperly gapped spark plugs. Gap too small = incomplete burn = maybe gas getting in the oil... Apparently a lot of new Hyundais are shipped with improper gaps. Just a thought: Check yo gaps!
Old 05-26-2011, 06:03 PM   #33
Ill stick to my slow audis and let my turbo problems happen after 100k. lol
Old 05-26-2011, 06:11 PM   #34
Which is like 20k after all of the instrument cluster, gauges and all of the electronic bullshit in the vehicle decide to call it quits.
Old 05-26-2011, 06:35 PM   #35
boostedcoupe
TD04-13T FTL
+rep
Old 05-26-2011, 07:23 PM   #36
125k. Still going strong. three audis, never had instrument cluster go bad. You just lost your ride in the A3 bitch.
Old 05-26-2011, 07:25 PM   #37
Someone wants a ride in an A3 like it's something special?
Old 05-26-2011, 07:28 PM   #38
He did! when i got it he wanted me to bring out to go for ride! lol
I mean.... its just a car! lol
But i like how people crack on my cars for stuff they heard people say about other audis, that has never happened to mine. Hell the cluster problem was on the old a6 and s4. only affected certain cars. RFB thinks that every audi since 1912 has had those problems.
Old 05-26-2011, 08:18 PM   #39
srt21
I FASTR
srt21's Avatar
most do
99 FRC Corvette Vararam/LT Headers/TI Mufflers
2008 350z (shoulda bought a vette) SOLD
99 Infiniti G20 Touring (SOLD)
2006 Civic SI (reliable and awesome)
2003 Honda CRV
Old 05-26-2011, 08:21 PM   #40
Accord4tehloss!
Slow ass Audi
Accord4tehloss!'s Avatar
Accord4tehloss! is on a distinguished road
My electronics are all fine still. Only thing is some of the pixels in my info screen are hard to read when it's hot out.
Accord4tehloss! is offline   Reply With Quote
