12-13-2009, 01:01 AM
#1
jackass of all trades
Infamous B5 A4 wheel bearings...
Car = 98 B5 A4 1.8t quattro 5spd.
I know I have at least one wheel bearing going out because it makes a humming noise that increases in frequency and volume with vehicle speed. I *think* it's both of my rear bearings. I had the car on a lift yesterday and both rear wheels spun freely but with a very very very slight noise compared to the front. There wasn't any up/down or lateral play when yanking on the wheels that I typically see on Hondas with bad wheel bearings.
Is there a better way to diagnose this issue a little bit more definitively?
Should I just buy both rears and do both at same time to be safe?
Both fronts too?
thanks in advance!
12-13-2009, 01:53 AM
#2
Wheel Man
Mine are the same Dave, you are better off doing both rears, I will be doing mine in a week or two...
they shut up about 80-95 mph though.. just sayin...
01 wj, lifted and locked.
12-13-2009, 03:14 AM
#3
Dave, I ALWAYS replace suspension parts in pairs UNLESS they are from crash damage.
Would you replace brake pads on only one side????
Axles, Wheel Bearings, Rotors, etc.
12-13-2009, 03:28 AM
If you have access to a set of chassis ears, they make wheel bearing diagnosis much easier...
12-13-2009, 05:45 AM
#5
WTF are chassis ears???
Why do I picture Mike running around with bigwoofersnet on his shoulders here?
12-13-2009, 09:25 AM
#6
THE SHOW STOPPER
dang you should of asked me yesterday
all the knowledge around you & you jumped on css? lol
anyway i have done quite a few of these lil turds & the rears are 90% usually the problem, replace them in pairs.
just stay away from Vato-Zone bearings
Rob
Total Performance Racing
(513) 942-7020
tprace@yahoo.com
In House Dynapack Dyno
Authorized Dealer for
Precision Turbo,WELDON, ERL,Golden Eagle, Injector Dynamics,DSS Driveshaft Shop, FULL-RACE,T1,CP Pistons,ATP Turbo,Thermal R&D,Who's timeslip is this? Fuck it ,I am using it.Hondata,VP Race Fuels,Competition Clutch,AVID Racing,Mickey Thompson, Garrett Turbo
Competition Clutch, Wiseco Pistons, M&H Tire,SPEC Clutch MANY More
12-13-2009, 09:30 AM
#7
THE SHOW STOPPER
why do i feel like were on the tv show family feud.
anyway "chassis ears" are exactly what they sound like,
they are smalll ears with probe like wires that plug into a headset therfore detecting noises from different areas of the chassis.
example: if you have 4 probes pluged in put 1 probe on each shock & then go for a drive with your headset on & wait for your niose to sound & then you can moniter each probe to determine where the sound is coming from..
I thing your local Sprint store will carry the head sets & Ford had the Probe.
12-13-2009, 09:02 PM
#8
Clip to schock or anything that doesn't spin, plug into switch box, put on headphones, and listen for noises...
12-13-2009, 09:04 PM
#9
Ah, just fancy a stethoscope of sorts.
12-13-2009, 09:14 PM
#10
Yes, but it allows you to listen while driving the car at the same time.
12-13-2009, 09:17 PM
#11
Yes, I understand that part....one of those "oh shit, killer idea" which helps when customer is always bitching about little noises and such.
12-13-2009, 09:20 PM
#12
Which is exactly what I used it for lol. Customer had a Galant making "noises" that no one else heard. Mitsubishi said to replace the wheel bearing because they kept complaining, but we had no idea which one to replace. Hooked up the chassis ears and STILL couldn't tell, so we just picked one.
12-13-2009, 09:33 PM
#13
Im just playin.
Dave, i work in audi parts call me at the audi connection and I'll take care of you. I know they are like 86 bucks a side retail but I will see what's the best I can do since you'll want to do both./
12-15-2009, 05:03 PM
#14
Administrator
I just did my a few weeks ago. It took a weekend and I had to buy a shop press to remove the old bearing and press in the new one. To determine what side it was, I used two scientific methods
1. Had someone sit in the back seat and slide back and forth to see what side was the loudest
2. Listened while turning hard. If it gets louder when you are turning right, it is on the driver's side. Turning left, passenger side.
I found this write up and it made it a lot easier - http://audiworld.com/tech/wheel45.shtml
charlie
