WTB: guage cluster for 1995 civic ex - Cincy Street Scene
Go Back   Cincy Street Scene > The Mall > Car parts
Old 10-29-2008, 05:22 PM   #1
brett
mmmm, i like it!!
brett's Avatar
brett is on a distinguished roadbrett is on a distinguished road
Send a message via AIM to brett
let me know what you have and the mileage reading on said cluster. thanks,
brett
513.205.2706
S t a t e
brett is offline   Reply With Quote
Old 10-31-2008, 06:40 PM   #2
brett
mmmm, i like it!!
brett's Avatar
whos got one fellers? anyone?
Old 11-07-2008, 07:58 PM   #3
coolcivic
coolcivic is infamous around these partscoolcivic is infamous around these parts
i have one pm me
coolcivic is offline   Reply With Quote
Old 11-08-2008, 07:30 AM   #4
brett
mmmm, i like it!!
brett's Avatar
pm'd
Old 11-08-2008, 07:38 AM   #5
DEL SLW
Obbie1
DEL SLW's Avatar
DEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of light
Send a message via AIM to DEL SLW Send a message via Yahoo to DEL SLW
what's wrong with the one in your car now?
2002 RSX-S - work
1999 Frontier 4x4 - utility
2001 SW Z -fun
DEL SLW is offline   Reply With Quote
Old 11-08-2008, 09:17 AM   #6
brett
mmmm, i like it!!
brett's Avatar
the guage goes wacky sometimes...more often then not.
VSS code shows up as well, from time to time. i've done a bit of research and will go this route to begin with and see where it gets me.
brett
Old 11-08-2008, 10:43 AM   #7
grjp1988
Css RICER
grjp1988's Avatar
grjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nicegrjp1988 is just really nice
I have one reading 175k miles lmk
grjp1988 is offline   Reply With Quote
Old 11-08-2008, 05:06 PM   #8
brett
mmmm, i like it!!
brett's Avatar
thanks, grip. i will let you know if the earlier poster's deal falls through. i'd like something closer to 140-150k if possible. i will be in touch if need be. thanks!
brett
Old 11-08-2008, 05:24 PM   #9
DEL SLW
Obbie1
DEL SLW's Avatar
most likely it's the VSS. bad connection, either the part of the plug that keeps it connected is broke, and it's bouncing around causing loss of connection, one of the wires is loose, or the vss itself is actually damaged. plus it's easier to replace than the cluster. i MIGHT have one you can try out
Old 11-08-2008, 07:53 PM   #10
93 red ls
1 Cam 1 Goal
93 red ls's Avatar
93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough93 red ls is a jewel in the rough
Send a message via AIM to 93 red ls
ive got one....high miles on it....40 bucks.....it has a tach
new things coming in 2011
93 red ls is offline   Reply With Quote
Old 11-09-2008, 08:53 AM   #11
brett
mmmm, i like it!!
brett's Avatar
dude, robbie. you got to let me know man...i was just at the pad! if you have a spare, let me know. thanks,
brett
Old 11-09-2008, 12:13 PM   #12
DEL SLW
Obbie1
DEL SLW's Avatar
ha, i posted that at 5:30. you showed up 4 hours later. i completely forgot about it, even though i meant to talk to you about it
Old 11-09-2008, 01:06 PM   #13
brett
mmmm, i like it!!
brett's Avatar
no worries buddy. is there tranny specific VSS's? i know there are between the DOHC and SOHC stuff, but within SOHC trans, i am not sure. i would think all the sensors are the same (within the SOHC world), its just the ring on the internal gears/final drive that make the readings differ from tranny to tranny.
Old 11-09-2008, 01:12 PM   #14
RTE117
RIP Hot Rod
RTE117's Avatar
RTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really niceRTE117 is just really nice
I am having the same issue with my 95 EX, but I am not throwing the VSS code, and I cleaned the connection.
I think you can use a B series VSS, but you want to double check.
I believe mine is the cluster because if I push in the trip odometer reset, it usually shows the current speed.
It's goofy as shit.
RTE117 is offline   Reply With Quote
Old 11-09-2008, 04:42 PM   #15
DEL SLW
Obbie1
DEL SLW's Avatar
i'm pretty sure you can use a b series one with a D series
Old 11-17-2008, 08:41 PM   #16
AllMotorSi
AllMotorSi is on a distinguished road
Send a message via AIM to AllMotorSi
Brett, check the connection first like robby said. Even after i cleaned up the connector on mine it still didn't work, had to replace the connector all together. I'm pretty sure i have another connector in my toolbox at work. Also have a VSS. Let me know if you need either.
www.KMS-FAB.com
www.tuned1.com
AllMotorSi is offline   Reply With Quote
