12-23-2008, 12:04 PM
#21
146 on a conservative tune.
Anyone can go fast in an auto!
12-23-2008, 12:14 PM
#22
I have to shit my auto...does that count for anything
Anyone should be able to hook when you got 4 drive wheels hahaha
9.7@139.5 with the v6
Update: Turbo LSbandwagon build in process
12-23-2008, 01:27 PM
#23
That's a different kind of shifting!! You just have to push the lever forward!
A properly setup RWD car will kill a properly setup AWD car off the line.
Think about it...RWD...all your power and weight is transfered to the rear wheels...GOOD.
AWD....all the weight is transfered to the rear wheels, but 50% of the power goes to the front and 50% goes to the rear....BAD.
1.3x 60fts is ok for a setup RWD car. 1.4x 60fts is amazing for a setup AWD car and 1.3x's are almost unheard of.
Now once things are rolling...AWD cars definately have an easier time driving at high hp....its kind of a hold it to the wood and point and steer kind of thing!
12-23-2008, 02:17 PM
#24
Good points! I was just passing some time up here at work
12-23-2008, 04:23 PM
#25
SVT BAIT
Originally Posted by WhiteT
The PT-88 is a bad mofo. Dave Fiscus (the fast GN from this area) has gone 8.2 @ 170ish with that turbo with a V6 and DR's
My car has a PT-70GTQ, slightly different exhaust wheel than the GTS. With the 70mm turbo, my best last year was a 9.6 @ 142 with more left in the tune. The tune was fairly conservative imo....lots of boost (30psi), 10.8 a/f and 20 degrees of timing (high for my car would be 26 or so). Hope to start pushing the car next year
I think my turbo would be an ideal turbo for an upgrade on your setup, they say that the pt-88 is laggy for a street car so I didnt go that route...I had the chance to pick up a 88 but after I thought about it I wanted a upgrade 76gts
99 Formula
12-23-2008, 04:25 PM
#26
laggy??.....you have 5.7 liters of torque! Who gives a f*ck about lag!! I've got a laggy setup! My car makes like 100ft-lbs of torque at 2500RPM!!
12-23-2008, 04:27 PM
#27
I need to stay with the 70mm. I race in a heads up class with the same type of cars. Our turbo limit is 70mm. I wouldn't go bigger than that anyways...the 70 already puts the block at it's hp limit.
12-23-2008, 06:53 PM
#28
SVT BAIT
lol I cant take mine to 8k rpms like you so I gotta spool quick and then shift at 7k....lol....
#29
SVT BAIT
those blocks are not cheap I assume?
12-23-2008, 06:59 PM
#30
6.x liter
i may be upgrading to a bigger turbo at some point after i see what the GT42 will put down, the borg warner/airwerks S82-S88 are looking good. the 82mm is offered with a billet wheel for better spool and is rated at 1350hp. i should be able to see 8k rpm fine with the solid roller setup, conventional distributor, and standalone
12-23-2008, 07:33 PM
#31
SVT BAIT
s82 is a bad ass turbo..you dont really need to take it 8k imo, its all in the mid range if your going to pass or fail...
12-23-2008, 07:49 PM
#32
6.x liter
not realy sure i understand what your trying to say? so if i make good power midrange and its still climbing i should just stop and shift at 5k? ill take it to where i continue to make good power at....im confused yew ar dum
12-23-2008, 09:13 PM
#33
SVT BAIT
Im not dum and if your going to start running mouth then hop of this thread...
two we both know that turbo cars dont make peak power at redline, so what I said is you dont need to take it 8k when your peak power is in the mid range, I thought the same to bro.
12-23-2008, 09:41 PM
#34
6.x liter
ok mayb not 8k but i have no problem taking it to 7500 as long as a i am still making peak power and not droping off
12-23-2008, 09:52 PM
#35
6.x liter
also depends on the turbo if i go s82 or bigger i will need some good rpms to put it in its efficiency range, where a 74 mm will make peak power sooner
12-23-2008, 10:32 PM
#36
No reason why the gt42 shouldn't put out 1000whp. But will your car handle it consistently? Just run 55psi and call it a day.
570awhp pump gas (old worn out engine)
New engine making great power.
12-24-2008, 01:48 AM
#37
SVT BAIT
im taking my to 7-7200 ish tops, wont need to in most street races but will when its track time.
12-24-2008, 04:10 AM
#38
A 42 on a v8 and on a 4cyl are two differnt things. If perhaps the turbo had a big A/R it it may get close to 1000hp. Think a few v8 guys got close @870hp. One guy I spoke with picked up .5 and mph. switching to a borg with a bigger a/r. Thats my problem,I feel with my little 1.01 exhaust will be over ran by the size the motor.
12-24-2008, 03:19 PM
#39
6.x liter
as well as through an auto and 9'' theres goes 20+ % drivetrain loss im thinking the most the gt42 will be able to put down is 800-850. after i get it all together and get everylast part i need ill start talking to jose at forced inductions and see what he recommends, should be the borg warner s82-s91
12-24-2008, 06:09 PM
#40
SVT BAIT
he is the one that upgraded my 76gts
