clunking noise - Cincy Street Scene
Old 03-05-2010, 04:34 PM   #1
Metalheadinky
Metalheadinky is on a distinguished road
clunking noise
I know this is a ford thread but its a mercury cougar so is damn close to a ford. I got a 2002 mercury cougar that makes a clunking noise over bumps. I replaced the rear sway bar end links cause they were wore out. It sounds like its coming out of the rear. I just wanted to see if anyone else has had this problem. Thanks
Metalheadinky is offline   Reply With Quote
Old 03-05-2010, 04:40 PM   #2
nsaniti
OMNOMNOM
nsaniti's Avatar
nsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of lightnsaniti is a glorious beacon of light
drive it off a cliff, should help you diagnose the issue.
but on a serious note...did you check the bushings? even if theres no visible damage the sway bar could have lateral movement and be hitting the frame.
edit: fml spelling sucks when i wake up.
nsaniti is offline   Reply With Quote
Old 03-05-2010, 06:34 PM   #3
Bunjiro
Bunjiro's Avatar
Bunjiro has a spectacular aura aboutBunjiro has a spectacular aura aboutBunjiro has a spectacular aura aboutBunjiro has a spectacular aura aboutBunjiro has a spectacular aura about
Send a message via AIM to Bunjiro
Pretty much every ford in the world needs balljoints, check them fuckers out. Could also be shocks making noise, just depends on the type of clunk you are getting.
Bunjiro is offline   Reply With Quote
Old 03-05-2010, 06:39 PM   #4
Brennan
Brennan's Avatar
Brennan has a spectacular aura aboutBrennan has a spectacular aura aboutBrennan has a spectacular aura aboutBrennan has a spectacular aura aboutBrennan has a spectacular aura aboutBrennan has a spectacular aura about
i've seen some struts get super bad and noisy at honda before.
..or your muffler bearings
Brennan is offline   Reply With Quote
Old 03-06-2010, 11:52 AM   #5
Metalheadinky
damn muffler bearings. Ill check those out as well. Thanks guys.
