LSX build up - Page 2 - Cincy Street Scene
Old 04-13-2011, 12:23 PM   #21
I'd find the cheapest version and drop it in there. Get the car running and have some fun. While that is going on I'd have another long block project for big HP going on on the side.
Old 04-13-2011, 12:32 PM   #22
BTM
BTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to beholdBTM is a splendid one to behold
i would prefer to keep an aluminum block unless the cost factor is way too good to pass up. 90 pounds isnt a whole lot, but weight adds up.
if i can get a low miles engine that would be nice, so i wont have to rebuild, but im not completely against rebuilding.
i guess to go much further i will have to look into costs of different setups.
BTM is offline   Reply With Quote
Old 04-13-2011, 12:34 PM   #23
BTM
im also not looking for a high hp, gotta run 9 seconds car. if it gets to the point where im breaking axles and diffs, its time to back it off.
also, ls1 loves spray yeah?
Old 04-13-2011, 12:44 PM   #24
BTM
also, to give an idea of cost...
to continue with my current engine setup id be looking at spending 1k on a clutch, 1200 on a trans adapter kit, and 500-800 on an intercooler setup, and probably another 500 for more tuning.
so, thats kinda retarded. if you figure 3200 of would be spent money, plus money ill get selling a lot of the high dollar parts i have for my current setup, 3k min, 6k maybe, idk. i think i can get a lot of lsx love for 6-8k.
aside from the engine dropout, a premade swap kit is 1700, headers are about 700 to fit my chassis(but im sure i can use factory manifolds if i want), plus some extra for other things like power steering line, and swaybar relocation.
its money, but im not starting with nothing. all my ricer crap will sell for a decent chunk of change.
Old 04-13-2011, 01:14 PM   #25
Low mileage LS2/T56/ECU and wiring harness go for about $6000.
Old 04-13-2011, 01:38 PM   #26
faStE-R
i wanna go fast
faStE-R's Avatar
faStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to allfaStE-R is a name known to all
i dont see how you HAVE to buy all this stuff... i mean if you bought the same 400 dollar clutch that lasted you 6 years and put your car back together you still have a car that makes over 400 hp and its pretty reliable.
seems like your going to go through a lot of work to have less power. and im saying this as a friend not an LSX hater
faStE-R is offline   Reply With Quote
Old 04-13-2011, 02:13 PM   #27
You can get a complete LS1 dropout (engine+harness/ecm+t56) for between $4-6k, LS2 dropout for between $5-7k, and LS3 dropout is going to cost you over $8k
You can get an iron block motor for $600-1k, and get some 243 heads (ls6/ls2 factory) $700-800. A t56 alone will cost around $1500 (may be able to get ECU with it for that)
You can also get aluminum short block (5.7 or 6.0 (aka ls1/6 or ls2)) for $800-1200, then add on same as above.
Bottom line, you CAN get an lsx complete build (engine+trans+wiring/ecm) for as low as $3k, but will have to hunt, bargain, and assemble. Can get a good setup for under $5k for sure (again, may have to wait for hte right deals) and make the power you want.
I am the 53%
Old 04-13-2011, 02:36 PM   #28
BTM
less power, more reliability. its a trade im willing to take.
Old 04-13-2011, 03:08 PM   #29
Kevin Doe
Kevin Doe's Avatar
Kevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to beholdKevin Doe is a splendid one to behold
Send a message via AIM to Kevin Doe
I would have thougth that a complete LS1/T56 combo for low miles would be a lot cheaper than $5k now. I paid $5700 for mine a long time ago. I would have thought $3500 for the dropout would be obtainable for lowish miles.
Steamroller
Kevin Doe is offline   Reply With Quote
Old 04-13-2011, 03:21 PM   #30
Blue99fbody
zip em up!
Blue99fbody's Avatar
Blue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to beholdBlue99fbody is a splendid one to behold
Send a message via AIM to Blue99fbody
you need to change your liscense plate from sr 4 life to sr 4 sale
98 SS m6
99 Z28 nbm m6
09 Trailblazer SS
11 silverado ccsb 6.2
03 ZX-6R 636
01 ktm 300exc
32' baja twin 454s
www.dolce-vita-photography.com
Blue99fbody is offline   Reply With Quote
Old 04-13-2011, 03:40 PM   #31
Hahahahahaha
Old 04-13-2011, 03:49 PM   #32
BTM
lol, actually as of saturday the damn car wont be licenced at all. out of commission.
but, it will be back on the road some day, all straightened out and just the way i want it.
what is a good site to check out for more lsx info that has a widely used classifiedes section so that i can fiure out some ballpark prices on parts ill need.
Old 04-13-2011, 03:59 PM   #33
ls1tech
Old 04-13-2011, 04:09 PM   #34
BTM
ill poke around ls1tech for engine porn. did a little searching in the classifieds and didnt come across any dropouts. ill do some hunting around when i decide what i want to do.
Old 04-13-2011, 04:15 PM   #35
Blue99fbody
zip em up!
They have a separate classified in the midwest section as well
Old 04-13-2011, 04:32 PM   #36
4DooR_SuprA
Fancy Lancer
4DooR_SuprA's Avatar
4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice4DooR_SuprA is just really nice
SR not cutting it? ;)
4DooR_SuprA is offline   Reply With Quote
Old 04-13-2011, 05:16 PM   #37
DEL SLW
Obbie1
DEL SLW's Avatar
DEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of lightDEL SLW is a glorious beacon of light
Send a message via AIM to DEL SLW Send a message via Yahoo to DEL SLW
on the first page..
complete LS1 dropout. comes with more stuff than you'd even need $2500
http://www.ls1tech.com/forums/parts-...lete-swap.html
2002 RSX-S - work
1999 Frontier 4x4 - utility
2001 SW Z -fun
DEL SLW is offline   Reply With Quote
Old 04-13-2011, 05:29 PM   #38
Sean
Wife's Car
Sean's Avatar
Sean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to allSean is a name known to all
Send a message via AIM to Sean
I didn't know your car was that unreliable? Seems like you've been out running the same setup for years. Parts wear down man. I mean if you're wanting to go through all this swapping business why not just sell the car and buy a vette?
95 Talon - 2.0,s475, Cornfed
08tbss - not a race truck
Sean is offline   Reply With Quote
Old 04-13-2011, 05:39 PM   #39
bigwoofersnet
Click.
bigwoofersnet's Avatar
bigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud ofbigwoofersnet has much to be proud of
Send a message via AIM to bigwoofersnet
Originally Posted by DEL SLW View Post
on the first page..
I mean, I'm no LS1 expert... but that looks like it's only a trans.
bigwoofersnet is offline   Reply With Quote
Old 04-13-2011, 05:43 PM   #40
BTM
can it.
on the first page..
thats a auto to manual swap setup, no engine. thanks for the heads up though.
its not really unreliable, but its quirky, and a pain in the ass. lets put it another way, im bored with this big turbo sr nonsense, and i want something that will make me excited about the car again. im not at all interested in owning a corvette, i like my 240, just want to change it up a little. if i said i was going to swap in a vq35 the nissan guys wouldnt have bad things to say. just because its an ls1 people have to cry.
