Civic trans/axle seal - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Engine Tech
Old 11-25-2008, 11:09 AM   #1
im badass
CCS Colerain Crew
im badass can only hope to improve
my civic has a manual trans and the drivers side trans/axle seal started leaking. I replaced it and it still leaked. I pulled the axle again and the seal seems to be almost popping out, I put another seal in it seeings as they're only 5 bucks it was worth another try. Still leaking. The seals don't seem to stay in there tight. Any suggestions?
im badass is offline   Reply With Quote
Old 11-25-2008, 01:14 PM   #2
96integraG3
turbo honda
96integraG3's Avatar
96integraG3 is on a distinguished road
Send a message via AIM to 96integraG3
make sure there is no oil were the seal sits, buy the seal from honda they are like 2 bucks more
96integraG3 is offline   Reply With Quote
Old 11-25-2008, 03:21 PM   #3
I will only use Honda Seals for transmissions.
Also order the Civic axle seals from 92-95 for ALL 88-00 trannys, Honda has the part numbers messed up for 88-91 drivers side axle seals.
Tags
axle, civic, seal, trans
