car wont start - Cincy Street Scene
Old 08-20-2012, 05:11 PM   #1
grandmaGTP
shit dang
grandmaGTP's Avatar
grandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of lightgrandmaGTP is a glorious beacon of light
car wont start
Well after going to the track the other week, car died on the way home, thinking i was out of gas, (guage doesnt work) added gas to it and tried to start it, just sat there and cranked, check the fuel pressure gauge inside the engine bay and its not reading anything. Tank is atleast half full, I don't hear the pump at all when priming the car up. Don't think its just a clogged filter, leaning towards a bad pump but not sure how to check that.
Any ideas on what it could be or how to test the pump??
grandmaGTP is offline   Reply With Quote
Old 08-20-2012, 05:40 PM   #2
sbcxtreme
sbcxtreme's Avatar
sbcxtreme will become famous soon enoughsbcxtreme will become famous soon enoughsbcxtreme will become famous soon enoughsbcxtreme will become famous soon enough
Send a message via AIM to sbcxtreme
Did you try hooking a hot and a ground from the battery to the pump?
97 Talon - bone stock
sbcxtreme is offline   Reply With Quote
Old 08-20-2012, 05:46 PM   #3
grandmaGTP
shit dang
grandmaGTP's Avatar
i have not yet
Old 08-20-2012, 06:06 PM   #4
sbcxtreme
sbcxtreme's Avatar
Don't you think that would be a good way to test the pump?
Old 08-20-2012, 06:14 PM   #5
lol, smartass
Old 08-20-2012, 06:17 PM   #6
Loose ground somewhere?
Old 08-20-2012, 06:22 PM   #7
grandmaGTP
shit dang
grandmaGTP's Avatar
well the codes im getting right now are,
Fuel Pump Primary Circuit Malfunction
Turbocharger Wastegate Solenoid A Malfunction
Fuel level Sensor Circuit High Input
and if i would have thought about doing that, I dont think i would have asked for suggestions on here...
Old 08-20-2012, 06:27 PM   #8
Umm, check for fuel pressure. Vatozone I think you can rent a gauge from. Screw it in the schrader on the fuel rail.
Damn checkbook racers....
Old 08-20-2012, 06:32 PM   #9
grandmaGTP
shit dang
grandmaGTP's Avatar
have a gauge hooked up in the engine bay, its not reading any pressure
Old 08-20-2012, 06:41 PM   #10
quadturbopower
quadturbopower's Avatar
quadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nicequadturbopower is just really nice
Is the flux capacitor completely charged?
On a serious note, try hot wiring the pump before checking everything else. It is usually the most expensive thing that can go wrong so you might as well start there.
quadturbopower is offline   Reply With Quote
Old 08-20-2012, 07:01 PM   #11
Jesse
Slow race car
Jesse's Avatar
Jesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to beholdJesse is a splendid one to behold
Send a message via AIM to Jesse
Checked the fuel pump fuse?
Jesse is offline   Reply With Quote
Old 08-20-2012, 07:05 PM   #12
Crank it and have a buddy beat on the tank.
Old 08-20-2012, 08:56 PM   #13
which side is the fuel door on? could be the issue
Old 08-20-2012, 09:12 PM   #14
Its ok, its not red.
Old 08-20-2012, 09:16 PM   #15
sbcxtreme
sbcxtreme's Avatar
Hotwire the pump, if it comes on and the gauge shows pressure, then check wiring/fuses/relays. If it comes on and doesnt build pressure, I would disconnect the closest hose to the pump and try it again to see if its actually pumping.
Do you know anybody that has a scanner with the ability to turn on the fuel pump through the ecu?
Old 08-20-2012, 09:28 PM   #16
dsmawd350
6.x liter
dsmawd350's Avatar
dsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to beholddsmawd350 is a splendid one to behold
Send a message via AIM to dsmawd350
Originally Posted by sbcxtreme View Post
Do you know anybody that you can drop the car off too walk away and comeback when its fixed
dsmawd350 is offline   Reply With Quote
Old 08-20-2012, 10:02 PM   #17
jdredd
jdredd is on a distinguished road
just pull the thing out through the access door in the trunk.
Then just hook a 12v connect to it to test it.
Either relays up front bad (rare) or the pins to the relays fudged (happened to me)
or just dead pump (happens)
If you have any of the rewire crap check connections. If its the CHEAP rewires, check the ground wire. I had one years ago, and screw that came with it rusted.
Jumping pins 20 and 87 for the relay will run the pump. I think this is the right pic..
Sent you a PM ...
Project Turdbo GP
10.41 @ 132.64
http://turbo3800.com
jdredd is offline   Reply With Quote
Old 08-21-2012, 05:38 PM   #18
snapsmagee
LSX
snapsmagee's Avatar
snapsmagee is on a distinguished road
99.9999% of the time on one of the generals great automobiles its the fuel pump the vanes inside the pump come apart just change the fuel filter when u put the new pump in o and get an airtex or delco they seem to hold up the best and ur gauge doesnt work because the fuel card on the pump is bad gm has had this problem for quite some time now the contacts burn thru when it sweeps
snapsmagee is offline   Reply With Quote
Old 08-22-2012, 09:30 AM   #19
Originally Posted by snapsmagee View Post
Your gauge doesnt work because the fuel card on the pump is bad gm has had this problem for quite some time now the contacts burn thru when it sweeps
This has been a big problem with vehicles that have had the reformulated fuels that Ky had implemented years ago ran through their systems. When Ky was forced into emission testing they changed the type of reformulated gas they have for the summer months.
Old 08-27-2012, 08:37 AM   #20
v6motorheadftop
All slow no go
v6motorheadftop will become famous soon enoughv6motorheadftop will become famous soon enoughv6motorheadftop will become famous soon enough
snapsmagee is most likely right. The pumps on most GM cars pre 2005 would not last longer than 75k miles. I would guess it would be the pump, which in your case isn't a bad thing since you have the trap door. I would throw a walbro in their and modify the bucket. If you need help, lmk
v6motorheadftop is offline   Reply With Quote
