04 GTO voltage issue - Page 3 - Cincy Street Scene
Old 12-03-2011, 10:23 AM   #41
Wheelin
Wheelin's Avatar
Wheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really niceWheelin is just really nice
I'd check your flux capacitor or maybe the muffler bearing?
Automatics win races and manuals impress high school kids......
Racing from a roll is like beating off...sure its fun but its not the real thing.
Wheelin is offline   Reply With Quote
Old 12-03-2011, 12:51 PM   #42
Karr
Hood Romper
Karr's Avatar
Karr is infamous around these partsKarr is infamous around these parts
They looked fine when I checked them last night
Straight Hood Rompin'
RIP C45
Karr is offline   Reply With Quote
Old 12-03-2011, 02:46 PM   #43
NateZ28
lsx nutswinger
NateZ28's Avatar
NateZ28 is on a distinguished road
I had the same issue, on my 99ss, Turned out to be the clip that clips onto the alternator / voltage regulator...but could be a ground, very frustrating good luck
NateZ28 is offline   Reply With Quote
Old 12-03-2011, 03:08 PM   #44
Karr
Hood Romper
Karr's Avatar
I appreciate all the info. I'll look into all of those possibilities
Old 12-03-2011, 04:28 PM   #45
Originally Posted by ej1bmx View Post
You should probably just put it up for sale with "no issues" and hope somebody from CSS buys it.
Old 12-03-2011, 05:17 PM   #46
Lt. Dangle
Lt. Dangle is infamous around these parts
I'd check my wife
Regulated
Lt. Dangle is offline   Reply With Quote
Old 12-03-2011, 11:35 PM   #47
Karr
Hood Romper
Karr's Avatar
My buddy Brett looked into it a little more and said ground G102 could be causing the issue. I've googled and yet i still can't seem to find the location of it. Anyone have any ideas?
Old 12-04-2011, 02:57 PM   #48
Can't find a copy of the factory service manual online?
Old 12-04-2011, 11:23 PM   #49
Karr
Hood Romper
Karr's Avatar
Ending up getting my hands on one. Spent an hour cleaning the ground that was the suspected issue and still no results...FML.
Old 12-05-2011, 11:00 AM   #50
Originally Posted by Karr View Post
I threw a voltage stabilizer on the battery and it actually helped somewhat. Maybe I don't have enough juice?
Typically with a GM the flickering lights is caused by a bad solder connection on the BCM (hair line fracture).
Being that you checked it, I'd say your Alt isn't supplying enough current during idle. Eventhough you might have a 110 amp alt. most don't supply that kind of current at idle. Add an underdrive pully and the problem gets worse.
Make sure you have a good chassis to engine ground as well
Also, the Auto Zone checks is usually at speed and doesn't check the full range. You need to check the alt. output with an oscilloscope. I had a bad alt that tested good at Auto Zone but when I hooked it up to my analyzer the ripple was bad.
