Ford 4.0 SOHC Chain issues/rattle - Cincy Street Scene
Old 02-28-2010, 11:26 PM   #1
Basic info for those who own any 4.0 SOHC engine....
Some info here:
http://www.explorerforum.com/forums/...d.php?t=163298
I'll update as I gather info and links.
As you can see they use plastic guides on the timing chains. They wear over time and start to make noise upon startup and sometimes while driving. It sounds similar to spark knock or a "rocker arm" tick...
The replacement of the "cassettes" is quite involved and requires removal of the engine or transmission to do the rear chain on the passenger bank of the engine... I recommend removing the engine and doing it on a stand as it is easier to align the chains without standing on your head in the truck.
To setup the timing you will need the OTC fixtures. There are no keyways on the cams or jackshaft. I have the Ford master kit and would lend/rent it if someone needs it. I rarely use it anymore.
Some 4wd engines used a balance shaft and have 4 chains, if you have it out, do the guides on it too.
I have seen this issue cause chain failure and major engine damage if left alone long enough. If your truck is making the noise it's a good idea to research any TSB's or recalls that provide dealer assistance as it is a very costly repair.
Old 02-28-2010, 11:56 PM   #2
Broken tensioner on the main jackshaft chain.
OTC tools
Old 03-01-2010, 12:10 AM   #3
apocalypse
apocalypse's Avatar
apocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant future
I wish this thread had popped up a few weeks ago, i would have snapped pics of the one we did. We actually took the trans out and didn't have problems aligning everything
apocalypse is offline   Reply With Quote
Old 03-01-2010, 07:31 AM   #4
meatmarket
Wheel Man
meatmarket's Avatar
meatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the roughmeatmarket is a jewel in the rough
I've heard/done quite a few of these, they make a noise like the world is ending...
01 wj, lifted and locked.
meatmarket is offline   Reply With Quote
Old 03-01-2010, 10:55 AM   #5
Hmmm, I'll call Ford and see if there is a recall for my truck. Mine is an 02' so I think it's part of the affected trucks. I have a rattle on cold start up, but once it's running, it doesn't make any noise and runs perfectly. It's true what they say though, v8 gas mileage with 4cyl performance haha.
