anyone know how a car can lose a tune? - Page 2 - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Dyno / Tuning
Old 10-11-2011, 05:33 PM   #21
mx-5 man
mx-5 man is on a distinguished road
Originally Posted by shiftdrift View Post
Wastegate issue, leaky/clogged injector. Any exhaust leaks going to turbo? I wouldn't think it would just lose the tune, if the chip isn't loose check your injectors, its easy to pull and clean them. Are they 550's? Have you checked all your vaccumm lines?
chip is still good, maybe something with the fuel injectors, was running completely fine till about 2 months ago, 30psi and rich as normal, no exhaust leaks found, yes they are hks 550, vacuum lines look good, what should i look for on the wastegate? car starts leaning out real bad when getting to 16 psi is why i thought the tune was messed up
mx-5 man is offline   Reply With Quote
Old 10-11-2011, 05:34 PM   #22
mx-5 man
Originally Posted by shdw on th sun View Post
it ran out of 40 rolls
yup no more 40 rolls only egg rolls
Old 10-11-2011, 05:35 PM   #23
mx-5 man
Originally Posted by EvoVIIIFL View Post
did you somehow lose the ECU it was on?
nope still have the same ecu that was in it, im runnin a z32 maf maybe that is bad?
Old 10-11-2011, 05:50 PM   #24
shiftdrift
Banned
shiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these partsshiftdrift is infamous around these parts
I think you mean 20psi? 30psi is too much for a 2871. The maf could be going out, try taking it off and spraying off with brake clean the sensor in it, or swapping it out with one if you have access
shiftdrift is offline   Reply With Quote
Old 10-11-2011, 05:52 PM   #25
apocalypse
apocalypse's Avatar
apocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant futureapocalypse has a brilliant future
Well if you were running 30psi, then there's your issue. Turbo is toast, and motor probably is too.
Subscribe to my YouTube faggots...
http://www.youtube.com/user/apocalypse7011?feature=mhum
apocalypse is offline   Reply With Quote
Old 10-11-2011, 05:55 PM   #26
Mike
Fat Ricer Admin
Mike's Avatar
Mike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud ofMike has much to be proud of
Send a message via AIM to Mike
Lol @ 30psi.
Mike is offline   Reply With Quote
Old 10-11-2011, 06:03 PM   #27
srt21
I FASTR
srt21's Avatar
srt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nicesrt21 is just really nice
Send a message via AIM to srt21
Hopefully you're talking about fuel pressure and even then that's below 3bar.
srt21 is offline   Reply With Quote
Old 10-11-2011, 07:43 PM   #28
mx-5 man
meant 20 lol damn typos fml
Old 10-11-2011, 07:44 PM   #29
mx-5 man
im swappin the maf tomorrow
Old 10-11-2011, 07:47 PM   #30
mx-5 man
could the boost controller be messed up im runnin an aem truboost it has a built in alarm when it builds too much boost in drops it back to stock, but hopefully the maf is the reson its running lean
Old 10-11-2011, 07:48 PM   #31
mx-5 man
turbo is good and so is the motor checked them both first, and i have over 14 grand in the motor alone so its no really going to have a problem, charge pipe is good on the turbo too
Old 10-11-2011, 07:52 PM   #32
srt21
I FASTR
srt21's Avatar
Built LS7 with 8 2871s?????
Old 10-11-2011, 07:58 PM   #33
apocalypse
apocalypse's Avatar
You have 14 thousand dollars in a motor with a 2871? You're doing it wrong.
Old 10-11-2011, 08:03 PM   #34
mx-5 man
wanted a quick spooling turbo that's why i opted for it, don't care to go any bigger, ran 12.7 a month ago at edgewater so im completely satisfied
not really going for high horsepower, setting it up as my drift comp car for next year
Old 10-11-2011, 08:05 PM   #35
mx-5 man
nope lol chevy motors are not meant for an import
Old 10-11-2011, 08:07 PM   #36
oohhh, wrong thing to say here on LSxscene. LSx should be the only motor in the world and every other motor should be cut in half
Old 10-11-2011, 08:08 PM   #37
mx-5 man
most motors should be cut in half along with most cars
Old 10-11-2011, 08:11 PM   #38
mx-5 man
people can have their lsx swap cars but i refuse to own one
Old 10-11-2011, 08:12 PM   #39
apocalypse
apocalypse's Avatar
Jesus. Mine went 12.30's and didn't have 14 grand in the whole damn car...
Old 10-11-2011, 08:13 PM   #40
mx-5 man
good to hear edgewater sucks when your not using slicks
