2004 honda accord vibration issue - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Car Specific Forums > Honda / Acura Discussions
Old 07-12-2012, 08:31 PM   #1
theslantstudio
slightly slanted
theslantstudio's Avatar
theslantstudio has a spectacular aura abouttheslantstudio has a spectacular aura abouttheslantstudio has a spectacular aura abouttheslantstudio has a spectacular aura abouttheslantstudio has a spectacular aura abouttheslantstudio has a spectacular aura about
well this problem has been going for a few months now.
When i drive on the highway between 60-65 mph i get violent vibrations when im cruising above or below that speed im fine. Ive had my tires balanced rotated and aligned recently. Google search shows that its a cv axle issue but all the local parts stores think it something else. Anyone have any idea what it might be or how i could find out how to fix this problem
" i have three kids and no monies, why cant i have no kids and three monies"
theslantstudio is offline   Reply With Quote
Old 07-12-2012, 08:36 PM   #2
push
BAZINGA!
push's Avatar
push With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSxpush With all this rep, they must own an LSx
Send a message via AIM to push
Hit any potholes?
push is offline   Reply With Quote
Old 07-12-2012, 08:57 PM   #3
What type of balance was done on the tires? If it was just a static balance then you could very well have a "roadforce" issue present.
A road force balancer would show discrepancies in tire out of round or bent wheel issues.
Are they stock wheels?
If after market are you using hub centric rings?
Old 07-12-2012, 10:32 PM   #4
And yes horribly fucked axles will do the same thing. Usually you can grab a hold of the outer joint region and manhandle it enough to feel the play if they are fucked up enough to cause a bad vibe. I repaired a Kia sephia that had thoroughly fucked axles and a bad vibe.
And broken belts in your tire will do the same thing.
Old 07-13-2012, 04:59 PM   #5
theslantstudio
slightly slanted
stock wheels with good year tires
i got my wheels aligned and balanced at bob summeral on colerain ave not sure what they use i think i still have the printout in my car
Old 07-13-2012, 05:16 PM   #6
Sounds to be low on LSx
Old 07-13-2012, 07:48 PM   #7
^^ This
