LT1 Spark Plug Wire Routing? - Cincy Street Scene
Go Back   Cincy Street Scene > Automotive > Tech > Domestic Tech
Old 11-13-2008, 06:35 PM   #1
BowTieBill
BowTieBill is on a distinguished road
I have an LT1 Camaro and I have MSD 8.5mm spark plug wires. It goes around the Alternator & A/C bracket. The wires are too close to the bracket because at high RPMs it misses. I got done running it at the track and the next day the engine light came on and gave me a random cylinder misfire. So I was wondering if anyone has any suggestions on how to route the wires, or if I should buy over the valve cover wire set? IDK for sure if the over the valve cover wire set will allow the wires to stay away far enough from the bracket. Any kind of suggestions will help me out. Thanks.
Sad LT1 Guy....
BowTieBill is offline   Reply With Quote
Old 11-13-2008, 06:41 PM   #2
Hot Rod
The Emperor
Hot Rod's Avatar
Hot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to beholdHot Rod is a splendid one to behold
Send a message via AIM to Hot Rod
I think it misses because you had MSD wires, lots of people including myself have had bad luck with those. Unless they're crossed being close won't be too much of a problem.
Also what spark plugs? hopefully NGK's or AC Delco's, anything else toss em in the trash.
Hot Rod is offline   Reply With Quote
Old 11-13-2008, 07:45 PM   #3
gemballa996t
gemballa996t has a spectacular aura aboutgemballa996t has a spectacular aura aboutgemballa996t has a spectacular aura aboutgemballa996t has a spectacular aura aboutgemballa996t has a spectacular aura aboutgemballa996t has a spectacular aura about
Send a message via AIM to gemballa996t
second on the ngk's, i've had good luck with my msd wires. i had some taylor high temp and burnt through
them.
so a deer was trying to eat my rice.
gemballa996t is offline   Reply With Quote
Old 11-14-2008, 08:59 AM   #4
BowTieBill
I have NGK TR55 on it. I have been thinking about going with a taylor wrie set. Also another queston for you, but what do you think I should gap the plugs at? I have had the heads street ported and I got a little bit bigger Cam in the car. Nothing too crazy. Thanks for your help.
Old 11-14-2008, 09:00 AM   #5
BowTieBill
them.
So you're thinking I just have the wires routed bad? How do you have your wires routed on you LT1? Thanks...
Old 11-14-2008, 10:26 AM   #6
95BadNaTa
1.4L's of Fury
95BadNaTa's Avatar
95BadNaTa is on a distinguished road95BadNaTa is on a distinguished road
Send a message via AIM to 95BadNaTa
LT1 spark plugs and wires. i remember those days
95BadNaTa is offline   Reply With Quote
Old 11-17-2008, 02:55 PM   #7
bestracing
Someone took my Swingline
bestracing's Avatar
bestracing has a spectacular aura aboutbestracing has a spectacular aura aboutbestracing has a spectacular aura aboutbestracing has a spectacular aura aboutbestracing has a spectacular aura aboutbestracing has a spectacular aura about
I'd go with .035" to .040" on the plugs. I've had great results with MSD wires on a Gen I motor as well as my brother with his gen I motor cars and his 93LT1.
Before making assumptions, first look at the wires and make sure you haven't burned through a spark plug boot. Second look at the wires and make sure there isn't any wear marks where they are laying across the Alt. bracket. Last start the car when it's dark outside and raise the hood and see if you can see if the wires are leaking.
Last could be an opti or ICM going bad. Have you spaced the ICM off the head yet? A good mod to do with any LT1 vehicle. Gets the electronics off the hot head.
"While you are working on making something idiot proof someone else is working on making a better idiot"
1986 Trans Am - just for cruising and having fun
bestracing is offline   Reply With Quote
Old 11-17-2008, 03:00 PM   #8
Hot Rod
The Emperor
Hot Rod's Avatar
Like wayne said, the NGK TR55's like a lil tighter gap than the factory recommendation. Just double check to make sure wire's aren't crossed in a tight proximity and you should be golden.
Old 11-21-2008, 09:11 AM   #9
BowTieBill
Thanks a lot guys!!!
Old 10-28-2009, 07:47 PM   #10
GuitarCrazyo
GuitarCrazyo is on a distinguished road
Thanks for this info puckhead, I also confirmed in the UK owners manual that for our cars with EJ20G our spark plugs are: PFR6G like you say.
There is no mention of gap in the manual though, but I will go with whatever gap the current ones have.
GuitarCrazyo is offline   Reply With Quote
Old 10-29-2009, 04:06 AM   #11
1sicws6
JDM bum
1sicws6's Avatar
1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold1sicws6 is a splendid one to behold
Send a message via AIM to 1sicws6
Holy Fucking Thread Bump.
:2000 Trans Am Ws6:
If it ain't broke, I can't afford it.
1sicws6 is offline   Reply With Quote
Old 10-29-2009, 07:59 AM   #12
bestracing
bestracing's Avatar
Old 10-29-2009, 12:19 PM   #13
240Jeff
Riff raff
240Jeff's Avatar
240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all240Jeff is a name known to all
Send a message via Skype™ to 240Jeff
What the fuck are you talking about?
XBL Gamertag: GoonerArmy11
240Jeff is offline   Reply With Quote
Old 10-29-2009, 12:50 PM   #14
Speed Kills
SYR
Speed Kills's Avatar
Speed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to beholdSpeed Kills is a splendid one to behold
Send a message via AIM to Speed Kills
"The fuck you talkin' about?"
EJ20?? Subaru talk is --------> that way doadus.
"...I'm just not in the habit of seein' the Chevy work against a two-bit piece of junk..."
'99 Sportychop, '86 Jetta GLTD, '63 Comet, '55 Chivvy.
Speed Kills is offline   Reply With Quote
